Author |
Message |
raceitb22
Posted: Wed Mar 15, 2006 1:54 pm Post subject: Tire tires tires, I need suggestion on sizes for the rear, |
I want to go to a 170, however ive heard turn in will suffer, is that true, will it also hurt acceleration???/ anyhelp appreciated, also will the damn 170 even fit, I plan on using the same sidewall height(believe its a 60) if you where wondering
_________________ Brian Rush |
Back to top |
phlat65 Moderator
Posted: Wed Mar 15, 2006 11:20 pm Post subject: |
well, our wheel is 4.5 inches, so a 170 gets squeezed. the sides get steeper, and the bike will want to fall over. you can look at different 160 brands, and some will have more of a peak, and some will have a more flat profile.. Why the 170 anyway? this bike only makes 50 hp, if you can spin up a 160 out of corners, then something else is wrong, like tire pressure, suspension setup, riding position......
IMHO, a 160 is plenty of rear tire. I have scraped peg, never spun on exits when not wanted, and they are everywhere..
_________________ 2001 MZ Black Panther
Back to top |
Posted: Thu Mar 16, 2006 4:46 am Post subject: |
A 170 section tyre It will fit as far as I am aware, hoever I agree with the above coment, a 170 section tyre will not sit right on the rim, giving a distorted profile and may even put undue stress on the tyre.
As for the same height of tyre, the 60 in the tyre size refers to the aspect ratio. The height of teh tyre is 60% of its width, therefore the 170/60 will be 12mm larger in diameter.
_________________ Ride it like you stole it |
Back to top |
raceitb22
Posted: Thu Mar 16, 2006 12:34 pm Post subject: |
THanks for input, i was only wondering as wider is better(only sometimes) and before mz na went away, i called the main parts guy and he suggested a 170, and that he was using that size as well so i thaought id ask you peoples, your a tad more informative though, thats all thanks again
Back to top |
Posted: Thu Mar 16, 2006 7:53 pm Post subject: tire |
my saxon tour takes a 110/80x16 rear tire
and you can not find them in the usa
close is 120/80x16
and it jacks up the back almost 10mm
the fellow befor me had a 130/90x16 on it
talk about a bad handling quick steering bike
be careful playing with tire size
_________________ Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
www.qrz.com/wd8cyv |
Back to top |
F0ul_Oli
Joined: 01 Mar 2005 Posts: 103 Location: Deeside,North Wales,UK
Posted: Fri Mar 17, 2006 2:37 pm Post subject: |
Id agree with everyone here - standard sizes are the way to go.
If you are having a problem with grip, get some stickier tires - not that the standard MT60 are not sticky!!
Wider tires are just for looks and don't help you out on the corners!!
_________________ I will only run out of ways of modify the Baggy when it weighs less that 100 kg and runs 100 bhp at the back wheel!!
http://www.businessandit.co.uk - putting the IT in Profit! |
Back to top |
Chayanne
Joined: 03 Jun 2005 Posts: 48 Location: Mayaguez, Puerto Rico
Posted: Thu Mar 30, 2006 6:23 pm Post subject: Tire suggestion |
I have a MuZ Skorpion Tour 2002 I'm already change my rear tire from 150/60/17 to 170/50/17(Metzeler) I don't see any problems, but the seat is too hig to me, I can reach with the two feets but not plain (My legs height is 29-30 inches) if your 32-32 probably you don't see that problem.
Description: |
This is a MZ SKorpion Tour same year but isn'ot my unit... |
Filesize: |
61.56 KB |
Viewed: |
877 Time(s) |
_________________ Chayanne |
Back to top |
dmon722000
Joined: 28 Nov 2005 Posts: 51 Location: Ft. Lauderdale, Miami
Posted: Sat Apr 15, 2006 1:50 am Post subject: tire size |
160/60 rear and 120/ 65 front. Maxxis Goldspeed tires if you can stand replacing them every 3,000 miles (they kick so much ass I dont have enough room to tell you) or Bridgstone BT020 for great highmilage performance tires (O.E.M. on the Gsxr 600). Thats it. Oh, glad to hear your spinning up the rear on exits, keep it up!
Back to top |
