Author |
Message |
SeattlePaul
Posted: Thu Nov 09, 2006 3:21 am Post subject: Anyone know alternative turnsignals: Rt125, Baghira? |
If you have replaced your signals with something better--flexible stalk, maybe LEDs--I'd like to hear about it.
I broke a turn signal in a tipover. I can get an exact replacement from BSA-Regal, but the originals are so fragile and cheesy, I'd rather upgrade if I can afford it.
I I found out yesterday that the newer Triumph Speed Triple turn signals were an exact fit, and better quality...but at US$47.00, I was unwilling to replace all four. I was at the dealer with both the MZ and Triumph signals in hand, and I know they would fit. If you're feeling prosperous, go for it.
The Clear Alternatives lens upgrades *look* like they would fit the stock MZ...but that's just the lens and bulbs: http://clearalternatives.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CA&Product_Code=CTS-0003&Category_Code=TRIUMPH.1
I am asking Phil at BSA Regal to see if he knows. His price is HALF what my local dealer can get, so if I end up with the stock, at least I'll get a decent deal.
--Paul |
Back to top |
Drew
Joined: 17 Jul 2005 Posts: 84 Location: SF Bay Area (East Bay)
Posted: Thu Nov 09, 2006 3:20 pm Post subject: |
I believe Triumph and Kawasaki sourced many of their parts from the same vendor. Perhaps they did the same with signals. If so, then you've got a great lead (no shortage of Ninja aftermarket parts out there!). _________________ Relax. You'll live longer. |
Back to top |
Joined: 23 Nov 2003 Posts: 1118 Location: Parkersburg, West Virginia usa .You know the PARTS have been SHIPPED when the MAIL MAN knocks
Posted: Thu Nov 09, 2006 3:21 pm Post subject: turn signal |
there are some on some of the buell models that fit but same make
as mz also ktm duke will fit but as always
dig deep in back pocket
if intrested in the ktm duke ones i have a set in a box i can open and look up part numbers but there not cheap
bought them for a project bike custom bmw r75/2 _________________ Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
www.qrz.com/wd8cyv |
Back to top |
DEmark
Joined: 30 Dec 2003 Posts: 218 Location: Maryland USA
Posted: Thu Nov 09, 2006 4:04 pm Post subject: |
A couple of years ago, I bought an exact replacement turn signal for my Baghira at the Buell dealer for $5- a complete, new, turn signal, incredible price, the parts guy couldn't believe it. I think it was the Blast model. |
Back to top |
awschmidt
Joined: 07 Sep 2005 Posts: 41 Location: southern michigan, usa
Posted: Thu Nov 09, 2006 11:06 pm Post subject: |
I bought some enduro signals that looked identical except they had a flexible stalk. I think they were Baja Designs. Got them from my local Honda dealer. Hope this helps out.
Kevin |
Back to top |
SeattlePaul
Posted: Fri Nov 10, 2006 7:42 pm Post subject: |
Drew,
Thanks, that's one more resource at my disposal.
Dave,
Go ahead and post those part # for the record. More than $30 would be too much for me...if they don't match, I'd have to replace all 4 to get a matching set.
DEmark and Kevin,
I checked out both Buell and Baja design signals, and it looked like the mounting was different, with the wires running through the mounting stud. Did you have to drill out the mounting holes on your bike?
BTW I replied yesterday and the post never showed up.
--Paul _________________ www.cnvc.org
www.linuxaudio.org
www.ubuntu.com
www.giml.org |
Back to top |
DEmark
Posted: Fri Nov 10, 2006 9:27 pm Post subject: |
I definately did NOT do any drilling. I looked up the info I put on the MZOG site, it was a Buell Cyclone signal. |
Back to top |
awschmidt
Posted: Fri Nov 10, 2006 9:42 pm Post subject: |
I didn't have to change anything; However, I used them for the rear and I have a mastiff. I don't know if what you have is different.
Kevin |
Back to top |
SeattlePaul
Back to top |
DEmark
Posted: Sat Nov 11, 2006 5:08 pm Post subject: |
Yes, the rear signals look like that, the fronts also, but the fronts are attached without the big nut. Its only $5 Paul, buy one and try it. Take the old one to the dealer with you and compare. I don't have part #s, I should have posted them but I didn't, that last link you posted has pn's that are probably right.
Let us know what you find. |
Back to top |
SeattlePaul
Posted: Mon Nov 13, 2006 7:51 pm Post subject: Not a factory fit |
I have the turn signals. So far I haven't installed any. There are a couple problems:
1)The little peg on the base does not line up with the second hole in the bike. I can either cut it off or use washers to leave it enough space to clear.
2)The bike's wire harness will not fit through the stud. The bike's wires are sealed into a circuit module with potting compound, requring that they be cut in order to use the wiring that came with the signal.
3)There is not enough room inside the rear cowling for the mounting nut to turn. I have to spin the signal around instead, making accurate alignment difficult.
How did you guys deal with these fitment issues? Or, did your signals fit better out of the box?
BTW, they've gone up to $12-$15.00 each now. _________________ www.cnvc.org
www.linuxaudio.org
www.ubuntu.com
www.giml.org |
Back to top |
edec
Joined: 21 Jan 2006 Posts: 49 Location: California, USA
Posted: Tue Nov 14, 2006 11:22 am Post subject: |
The aftermarket turnsignals I have also gave me problems which required me to make a bracket (sort of cheap looking )out of a sheetmetal strap. Does anyone know of an exact fitting pair for the front (Baghira)? |
Back to top |
