Author |
Message |
-8-
Joined: 16 Jun 2004 Posts: 60 Location: Atlantic City,NJ
Posted: Thu Jul 01, 2004 3:17 pm Post subject: Baghira Rear shock adjust / Air Box |
Is it possible to adjust the spring ht on the rear shock without removing the airbox? If not, what's the easiest way to remove the airbox? |
Back to top |
phlat65 Moderator
Posted: Thu Jul 01, 2004 8:19 pm Post subject: |
yes, use a long brass drift and hammer to loosen/tighten the jam ring, support bike on jack and turn spring by hand, should move collar as well, or use drift to turn collar. _________________ 2001 MZ Black Panther
Back to top |
Brian
Joined: 19 Nov 2003 Posts: 252 Location: Seattle, Washington
Posted: Fri Jul 02, 2004 10:07 am Post subject: |
I pulled my exhaust pipe and mid pipe to use the wrench on mine....... _________________ "Brian" 2003 MZ Baghira |
Back to top |
sbaschn
Joined: 14 May 2004 Posts: 16 Location: Jacksonville, FL
Posted: Sat Jul 03, 2004 9:35 pm Post subject: Will that lower the bike a tad??? |
I just read your post. Will that esentially lower the bike a little??? |
Back to top |
phlat65 Moderator
Posted: Mon Jul 05, 2004 4:44 pm Post subject: |
kinda, but not in a good way. if you want to lower the rear, change the "dog bones". you can get them from MZ, or make them your self. _________________ 2001 MZ Black Panther
Back to top |
-8-
Posted: Thu Jul 08, 2004 5:26 am Post subject: |
Tore the jamp nut up some but got it down about 1/2". Just needed to drop that much so I can get at least 5 toes on the ground. |
Back to top |
