Author |
Message |
credit
Posted: Wed Mar 01, 2006 2:07 pm Post subject: race tech springs/ eibach |
does any one know which springs I need to stiffen my suspension on my reduced height baghira and is race tech and eibach the best place to get them
http://www.racetech.com/
________
cheap vaporizer
Back to top |
steveweck
Posted: Wed Mar 01, 2006 7:28 pm Post subject: springs |
I had just called Race Tech last week to find some springs and valves for my Skorpions forks. The guy there didn't have anything specifically for MZ. He said the measure the springs and he'd find the correct springs for me. Check out Hyperpro USA their website lists applications for the MZ's. They have kits for both the shock and forks.
Steve Weckesser
96 MZ Skorpion
Back to top |
credit
Posted: Wed Mar 01, 2006 10:17 pm Post subject: |
this is the rear shock for the Mastiff . will this fit the Baggie as well
but I could'nt find anything for the front forks
________
Lincoln V12 engine history
Back to top |
cat
Joined: 30 Nov 2005 Posts: 398 Location: South Africa
Posted: Mon Mar 06, 2006 11:15 am Post subject: Re: race tech springs/ eibach |
credit wrote: | does any one know which springs I need to stiffen my suspension on my reduced height baghira and is race tech and eibach the best place to get them
Race Tech are well-known for their Gold Valve improving the performance of less-than-good forks. I'd trust their springs. They will figure out a spring rate for you, but they won't be familiar with the bike (although you can give them its weight) and you'll be measuring springs that have already sagged.
Hyperpro are excellent. The guy that started the company is the guy that made White Power shocks - now called WP. He left when the company was taken over because he didn't like the corporate bs. If you've got the bux, get a Hyperpro shock. I think it will be the same length as the one on the full height bike; as far as I know the only differences are the rear suspension link arms and the front forks. I can't measure for you now because I'm at work. If you want to be absolutely sure, someone with a stand can measure theirs.
Back to top |
credit
Posted: Tue Mar 07, 2006 7:55 pm Post subject: |
cat I will go with eibach springs in the front. the shop doing the install ordered them. in the rear what should I do. Hyperpro say thhey don't have a direct replacement
________
teen vids
________
volcano vaporizer review
Back to top |
cat
Posted: Wed Mar 08, 2006 1:40 am Post subject: |
credit wrote: | cat I will go with eibach springs in the front. the shop doing the install ordered them. in the rear what should I do. Hyperpro say thhey don't have a direct replacement |
Ask MZ if the shock lengths are the same. I bet they are. Or you could check WP, see if they list shocks for both Mastiff and Baghira and if they're the same. Don't Hyperpro know? I'll measure my shock asap. The air box and rear mudguards and all are off, so I should be able to measure the shock and then check how much it extends when I lift the back. Then Hyperpro can come with the length of the Mastiff shock. But what's wrong with them? Why list a shock for the Mastiff and not the Baghira? They're lazy, they should find out. How many Mastiff owners are here compared to Baghira owners.
Back to top |
Posted: Wed Mar 08, 2006 7:30 am Post subject: |
I will check the parts cat tonight, but I am sure the Mastiff and height reduced Baghira share the same rear shock. The normal hieght Baghira definatly has a longer rear shock than the height reduced version.
Back to top |
cat
Posted: Wed Mar 08, 2006 8:14 am Post subject: |
keithcross wrote: | I will check the parts cat tonight, but I am sure the Mastiff and height reduced Baghira share the same rear shock. The normal hieght Baghira definatly has a longer rear shock than the height reduced version.
Keith |
oh. ok, then Credit can't move on the shock until we can get the length of the HR shock. Once we know that, then Hyperpro or anyone can supply a suitable one. The right spring rate can be estimated according to the bike weight and Credit's weight.
Back to top |
credit
Posted: Wed Mar 08, 2006 11:38 am Post subject: |
170lbs 5'8"
________
vapormatic
________
Jaguar XJS history
Back to top |
Posted: Wed Mar 08, 2006 12:45 pm Post subject: |
I've got the parts book in front of me and it says:
Centre to centre of mounting bolts
Baghira, Bahira Street moto - 425mm
Bahira HR, Bahira SM HR, Mastiff - 412mm
Spring length in untightend position.
Non HR models 260mm HR models and Mastiff - 240mm
Spring rate 75Nm and 85Nm respectively
I have various other recommended settings if you want them.
Back to top |
cat
Posted: Wed Mar 08, 2006 1:17 pm Post subject: |
keithcross wrote: |
There you go. (Thanks Keith!)
Now you can give that to Hyperpro and then - eventually - post some photos with your beautiful Hyperpro shock.
Back to top |
Hoke
Joined: 07 Feb 2005 Posts: 56 Location: Stockholm, Sweden
Posted: Mon Sep 18, 2006 7:14 am Post subject: |
keithcross wrote: | I've got the parts book in front of me and it says:
Keith |
Greate info
Do you know for what "riderweight" this is for?
I am looking for stiffer springs both for the fork and the shock, with me and all stuff the load on my bike is aboute 120kg (265lb).
Back to top |
Hoke
Posted: Tue May 08, 2007 4:23 am Post subject: |
Does anyone now what rate the stock front/fork-springs are?
After rek. from WP i changed the rear spring to a 95nm(for my 120kg on the Baghira Enduro) from the stock 75nm , and now i need to change the front springs to
Back to top |
kman.45
Joined: 06 Apr 2006 Posts: 65 Location: Knoxville Tennessee USA
Posted: Tue May 08, 2007 11:57 am Post subject: |
Do not know front spring rate, sorry. As a way of comparison. the 75Nm and 85Nm spring rates convert to 7.65 and 8.67 kilograms of force. You'll find the rates at Race Tech in Kg/mm I think.
If anybody remembers back to my front fork thread, Race Tech was not able to supply most of the correct bushings and seals for the front forks. They are Marzocchi Magnum 45mm forks. Turns out same as on like 98-99 KTM 200 according to one kid I talked too, as well as some Husky's and others. I turned to SF Moto for the fork internals and they were same price if not cheaper than Race Tech's, plus they shipped quicker.
Compared to other large singles the Baghiras are much better sprung for normal weight Brits/Germans/Aussies/Americans..
Stock KLR rear spring is like 5.1 kg/mm and stock DR650 is about 6.5 kg/mm. So I figured front must be too.
I too considered stiffening front (almost 100 kg rider) but since the bike is well balanced and I decided I'd like to keep most of the 11 inches of suspension travel I decided against stiffening it up to be like a sport bike.
Back to top |
omrra91
Posted: Sat Aug 04, 2007 3:22 pm Post subject: Race tech stuff |
I'm glad to hear people on the board talking about Race Tech parts. During the construction of my MZR road racer (see other post)I ended up with some spares. I don't know much about the Race Tech goodies, but here is what I have. A set of Cartridge Emulators in excellent condition. They came out of my 41mm TZR forks so I figure that with the correct length spacer and possibly different springs they will be a great improvement over the stock fork set up.
Regards, Jeffrey
Description: |
Filesize: |
9 KB |
Viewed: |
6028 Time(s) |
Back to top |
