Author |
Message |
bigzed
Joined: 08 Apr 2004 Posts: 31 Location: sunny essex uk
Posted: Thu Nov 04, 2004 3:04 pm Post subject: Gedge ! |
Or anyone else with a motrax led tail light,some wiring help needed,i'm shit with 'lectrics but i fitted said led light and i don't have a no plate light can you fill me in on the wiring please.Many thanks in advance.
Gary
also fitted acerbis diamond h/light which surprisingly does work |
Back to top |
gedge
Joined: 08 Jun 2004 Posts: 191 Location: Portsmouth, UK
Posted: Thu Nov 04, 2004 3:21 pm Post subject: |
Gary
On the UK models of the LED the lower section is clear and when the side light is on, it shines white light down on the number plate.. it doesnt have seperate lighting wiring.. Just make sure you didnt put it on upside down so that it lights up inside the rear fender |
Back to top |
hulagun
Joined: 13 Sep 2004 Posts: 138 Location: san francisco, CA
Posted: Thu Nov 04, 2004 5:01 pm Post subject: |
Anybody in the UK that can sell me a couple of those Motrax LED taillights? we can't gettem here except in all clear (with red LED). Clear stoplamp lenses don't appeal to me.
Ivan |
Back to top |
Posted: Thu Nov 04, 2004 5:19 pm Post subject: |
Cant create the link, but a guy had one of the units you want for sale on ebay a while ago. It might be worth trying to contact him. The item number was 7928432663.
Update, try item number 7930823603. Light is available with either red or clear lens.
BTW with the one currently connected, have you got it wired right. Doe the numberplate light work with the brake light. You may have the tail light/brake light connections reversed.
Keith _________________ Ride it like you stole it |
Back to top |
bigzed
Posted: Thu Nov 04, 2004 6:07 pm Post subject: |
When i put the lights on i get quite a dim glow,pull the brake it goes very bright but i don't got no white light at all for the plate must be a wire in the wrong place methinks . Cheers Gary |
Back to top |
gedge
Posted: Fri Nov 05, 2004 8:24 am Post subject: |
bigzed wrote: | When i put the lights on i get quite a dim glow,pull the brake it goes very bright but i don't got no white light at all for the plate must be a wire in the wrong place methinks . Cheers Gary |
I am not sure what you have done.. There are only 3 wires IIRC. 1 Sidelight , 2 brake light and 3 earth....
The Red lEDs glow pretty brght on side lights and then reallly bright when you brake. Part of the lens cover is clear and the leds above this are white, they shine onto the number plate......hope this helps |
Back to top |
bigzed
Posted: Fri Nov 05, 2004 1:46 pm Post subject: |
Ta mate,so simple but i just can't get my head round it hopefully get it sorted tomorrow, when she goes in for an oil change. Cheers the noo Gary |
Back to top |
micheleen
Posted: Fri Nov 05, 2004 2:24 pm Post subject: |
Brake and earth wires crossed
Cheers, Mike |
Back to top |
