MZ Riders
MZ DIY 150 conversion success
Post new topic   Reply to topic    MZ/MuZ Riders Forum Index :: 125 cc
Author Message
mxsteven
PostPosted: Thu Dec 21, 2006 8:35 pm    Post subject: MZ DIY 150 conversion success Reply with quote
Here the pics of my bike....
the Back mudguard had been removed and the air box had been removed too... battery located in the middle...
I had some problem with the block which the water jacket leaking from the outside, so i solved the problem with gasket sealant.... till now it works fine..
Will update more pics later...
Regards
MXsteven
 Description:
Engine View and air box compartment being removed
 Filesize:  92.52 KB
 Viewed:  3067 Time(s)
 Description:
Back view of my bike
 Filesize:  86.35 KB
_________________
Where u go, it's up to u,
Think b4 u do, Ride safe.
MXsteven
Back to top
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
Location: Parkersburg, West Virginia usa .You know the PARTS have been SHIPPED when the MAIL MAN knocks
PostPosted: Thu Dec 21, 2006 9:43 pm    Post subject: conversion Reply with quote
what piston did you use and did you use a steel liner or have some one
redo the nycil bore in the alunium cylinder
ar dav
_________________
Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
www.qrz.com/wd8cyv
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
mxsteven
PostPosted: Thu Dec 21, 2006 10:28 pm    Post subject: Reply with quote
i used the local bike 175cc piston... and rebore using hardened steel liner which pin end piston also need to be mod....
i also did smoke post and polish for intake and exhaust... tommorow im going to replace my carb. I havent decided what type of carb to change so i will try a few type of carbs and see which is the best.
MZ had a bug in the ignition... try to replace the ignition relay which is beside the CDI (white colour relay which had 5 pins) you can replace it to a normal automobile relay which you only use 4 pin.
2 pin for the relay coil and 2 pin for NO (normally open).
it improves the idling because the original relay had some current restriction in it which that 12v in but 5 - 8v out only and sometimes 3v only, then it will make some misfiring during idling.
Regards
MXsteven
ps: later i will take some technical picture and post it in
_________________
MXsteven
Back to top
Display posts from previous:
Post new topic   Reply to topic    MZ/MuZ Riders Forum Index :: 125 cc All times are GMT - 5 Hours
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
