Author |
Message |
Fil
Joined: 22 Jul 2005 Posts: 144 Location: Shropshire, England
Posted: Thu Dec 22, 2005 3:11 pm Post subject: Valve clearances |
Hi guys,
Could someone tell me what the valve clearances are for the Baggy/ Mastiff, and what size the nuts & screws are on the adjusters (so I can make sure I have the correct tools before I pull it to bits!!)
Back to top |
cat
Joined: 30 Nov 2005 Posts: 398 Location: South Africa
Posted: Fri Dec 23, 2005 7:16 am Post subject: Re: Valve clearances |
Fil wrote: | Hi guys,
Valve clearance (cold) :
intake: 0.10 - 0.15 mm (0.004” - 0.006”)
exhaust: 0.15 – 0.20 mm (0.006” – 0.008”)
i don't know what size the nuts and screws are. i couldn't find anything about XTZ 660 valve clearance adjustment when i searched a while ago. there are some nice tools for it, including those bent-over feeler gauges but they're all in inch sizes / thou, and i don't like that. the specs are in precise mm, it's a Japanese engine, and i want to use metric feeler gauges.
anyway, you should have the tools, already. like 1/4" drive (jees, inches again) 6mm, 8mm, 10mm sockets and spanners.
let us know.
Back to top |
Fil
Posted: Mon Jan 02, 2006 6:20 pm Post subject: |
Right, having had a go at doing the job, I thought I'd add comments from my experiance of doing this job earlier today for the benefit of anyone having a go at adjusting the valve clearances (altough if you're not sure what you're doing, leave it to your bike shop!!)
The lock nuts are 10mm, and the screws have a very small, square head on them which requires a special valve adjuster spanner to do correctly. I would definately recommend getting hold of one of these spanners before attempting this job! A pair of pliers just isn't going to do it I'm affraid!
To get at the exhaust valves on a Baggy/ Mastiff (don't know about the Scorpion/ Traveller as I don't have one!) you need to undo the radiators on both sides (no need to disconnect any pipes) and move them back as far as you can to get at the two round covers over the adjusters.
These you can remove with a 17mm ring spanner.
To get at the cover over the inlet valve adjusters, you need to work around the water pipe that runs over that part of the engine. I found I could move the pipe far enough out of the way after disconnecting the throttle cables. The inlet valve adjuster access cover is held in place by 4 bolts (using a 5mm allen key).
Also - be careful when removing the large circular cover in the centre of the left hand engine case to get at the 19mm nut on the alternator end of the crank (to allow you to rotate the engine to TDC) as it is only made of plastic.
And don't forget to remove the spark plug so that you don't have to fight the compression in the cylinder at TDC!!
All the torque settings etc are in the SZR manual which you can download from a link somewhere on here...
Hope someone finds this useful!
Back to top |
Joined: 23 Nov 2003 Posts: 1118 Location: Parkersburg, West Virginia usa .You know the PARTS have been SHIPPED when the MAIL MAN knocks
Back to top |
Fil
Posted: Tue Jan 03, 2006 3:54 pm Post subject: |
Thanks David - that's the one! I downloaded it a little while back and couldn't remember where I'd seen it...
Back to top |
cat
Posted: Wed Jan 04, 2006 1:41 am Post subject: |
Fil wrote: | The lock nuts are 10mm, and the screws have a very small, square head on them which requires a special valve adjuster spanner to do correctly. I would definately recommend getting hold of one of these spanners before attempting this job! A pair of pliers just isn't going to do it I'm affraid!
Strange..the only place I've ever seen them is on the internet, but so many cars use them, I don't know why you don't see them in ordinary car parts shops.
Fil wrote: | To get at the cover over the inlet valve adjusters, you need to work around the water pipe that runs over that part of the engine. I found I could move the pipe far enough out of the way after disconnecting the throttle cables.
Sounds like it wouldn't be easy to get the feeler gauge and spanner in there with the water pipe in the way.
Fil wrote: | Also - be careful when removing the large circular cover in the centre of the left hand engine case to get at the 19mm nut on the alternator end of the crank (to allow you to rotate the engine to TDC) as it is only made of plastic.
I was looking at that, wondering what I'd use to unscrew it. ...Maybe a ruler?
Back to top |
Posted: Wed Jan 04, 2006 2:40 am Post subject: |
To undo the plastic cirular plug, I modified a wood chiesel, making sure than all sharp edges were removed. Works well.
Back to top |
Fil
Posted: Wed Jan 04, 2006 4:19 pm Post subject: |
cat wrote: |
Sounds like it wouldn't be easy to get the feeler gauge and spanner in there with the water pipe in the way. |
It's a bit awkward, but not too bad with the right tools!
It wouldn't take much effort to drain the coolant and remove the water pipe from the head (just above the carb inlet stub on the right hand side) so you can move the water pipe out of the way.
I'll be investing in a set of angled feeler gauges too when I can find some!
Back to top |
cat
Posted: Thu Jan 05, 2006 2:13 am Post subject: |
Fil wrote: | cat wrote: |
I'll be investing in a set of angled feeler gauges too when I can find some! |
Always right tools. This time around I've got money - or at least compared to when I was 20 - so I go buy the tools. All I need now is a torque wrench that does 5-20Nm - and the valve clearance tools.
I think I've got pictures...there are some Wurth feeler gauges for valve clearance but they're quite hard to get, and about $27 for set of 2.) Then there are the Motion Pro ones - they're available all over the place - the web, I mean. They're not the old usual angled feeler gauges - which I haven't seen for years - since everything started coming from China, probably.
The Motion Pro ones ($4.35-4.75) (see picture below):
TAPPET FEELER GAUGE .002-.003
TAPPET FEELER GAUGE .004-.005
TAPPET FEELER GAUGE .006-.008
Also picture of Motion Pro tappet tool set; it looks good.
Description: |
Filesize: |
119.02 KB |
Viewed: |
1367 Time(s) |
Description: |
Filesize: |
5.36 KB |
Viewed: |
1367 Time(s) |
Back to top |
cat
Back to top |
Posted: Thu Jan 05, 2006 12:50 pm Post subject: |
When I last checked my valve clearances I used a set of tappet adjusters like the ones in your picture. They are very easy to use. As for feeler gauges I bend some normal ones to fit.
Back to top |
cat
Posted: Fri Jan 06, 2006 2:18 am Post subject: |
keithcross wrote: | When I last checked my valve clearances I used a set of tappet adjusters like the ones in your picture. They are very easy to use. As for feeler gauges I bend some normal ones to fit.
Keith |
Yes, that's what we've always done with feeler gauges. The tappet adjuster tools, the only way I'm going to get any is to order them from the USA and they're heavy, so expensive. Maybe I can get just the square type.
Back to top |
Posted: Fri Jan 06, 2006 11:52 am Post subject: |
I got mine from a company in teh UK called M&P a couple of years ago. Quite cheap if I recall. Dont know about P&P to where you live though
Back to top |
Fil
Posted: Fri Jan 06, 2006 1:57 pm Post subject: |
keithcross wrote: | I got mine from a company in teh UK called M&P a couple of years ago. Quite cheap if I recall.
Keith |
Those are the ones I've got. Motion Pro, £25 plus P&P from M&P.
Back to top |
cat
Posted: Mon Jan 09, 2006 2:34 am Post subject: |
Fil wrote: | keithcross wrote: | I got mine from a company in teh UK called M&P a couple of years ago. Quite cheap if I recall.
Keith |
Those are the ones I've got. Motion Pro, £25 plus P&P from M&P. |
Only about 10% less from USA, but shipping cost higher so about the same.
However, pitposse has copies. Which of these is the right one?
Posse Tappet Tool Set 9mm & 10mm
9mm & 10mm SOCKETS, 4mm SQUARE ADJUSTER, SINGLE CYLINDER AND MULTI-CYLINDERS.
MOST HONDA/YAMAHA.
Posse Tappet Tool Set 8mm & 10mm
8mm & 10mm ROCKER ADJUSTMENT NUTS SLOTTED AND 3mm SQUARE ADJUSTER, SCREW DRIVER & 3mm SQUARE-TIP APPLICATIONS.
KAWASAKI MODELS NINJA 600, 750, 900, 1000.
Description: |
Filesize: |
29.76 KB |
Viewed: |
1260 Time(s) |
Back to top |
