MZ Riders
Valve clearances
Goto page 1, 2  Next
Author Message
Fil
PostPosted: Thu Dec 22, 2005 3:11 pm    Post subject: Valve clearances Reply with quote
Hi guys,
Could someone tell me what the valve clearances are for the Baggy/ Mastiff, and what size the nuts & screws are on the adjusters (so I can make sure I have the correct tools before I pull it to bits!!)
Back to top
View user's profile Send private message
cat
PostPosted: Fri Dec 23, 2005 7:16 am    Post subject: Re: Valve clearances Reply with quote
Fil wrote:
Hi guys,
Valve clearance (cold) :
intake: 0.10 - 0.15 mm (0.004” - 0.006”)
exhaust: 0.15 – 0.20 mm (0.006” – 0.008”)
i don't know what size the nuts and screws are. i couldn't find anything about XTZ 660 valve clearance adjustment when i searched a while ago. there are some nice tools for it, including those bent-over feeler gauges but they're all in inch sizes / thou, and i don't like that. the specs are in precise mm, it's a Japanese engine, and i want to use metric feeler gauges.
anyway, you should have the tools, already. like 1/4" drive (jees, inches again) 6mm, 8mm, 10mm sockets and spanners.
let us know.
Back to top
View user's profile Send private message Send e-mail
Fil
PostPosted: Mon Jan 02, 2006 6:20 pm    Post subject: Reply with quote
Right, having had a go at doing the job, I thought I'd add comments from my experiance of doing this job earlier today for the benefit of anyone having a go at adjusting the valve clearances (altough if you're not sure what you're doing, leave it to your bike shop!!)
The lock nuts are 10mm, and the screws have a very small, square head on them which requires a special valve adjuster spanner to do correctly. I would definately recommend getting hold of one of these spanners before attempting this job! A pair of pliers just isn't going to do it I'm affraid!
To get at the exhaust valves on a Baggy/ Mastiff (don't know about the Scorpion/ Traveller as I don't have one!) you need to undo the radiators on both sides (no need to disconnect any pipes) and move them back as far as you can to get at the two round covers over the adjusters.
These you can remove with a 17mm ring spanner.
To get at the cover over the inlet valve adjusters, you need to work around the water pipe that runs over that part of the engine. I found I could move the pipe far enough out of the way after disconnecting the throttle cables. The inlet valve adjuster access cover is held in place by 4 bolts (using a 5mm allen key).
Also - be careful when removing the large circular cover in the centre of the left hand engine case to get at the 19mm nut on the alternator end of the crank (to allow you to rotate the engine to TDC) as it is only made of plastic.
And don't forget to remove the spark plug so that you don't have to fight the compression in the cylinder at TDC!!
All the torque settings etc are in the SZR manual which you can download from a link somewhere on here...
Hope someone finds this useful!
Back to top
Location: Parkersburg, West Virginia usa .You know the PARTS have been SHIPPED when the MAIL MAN knocks
PostPosted: Mon Jan 02, 2006 7:11 pm    Post subject: engine manual Reply with quote
http://www.mzriders.com/viewtopic.php?t=1210
engine manual link
listed in one of the posts under this heading
_________________
Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
www.qrz.com/wd8cyv
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Fil
PostPosted: Tue Jan 03, 2006 3:54 pm    Post subject: Reply with quote
Thanks David - that's the one! I downloaded it a little while back and couldn't remember where I'd seen it...
Back to top
cat
PostPosted: Wed Jan 04, 2006 1:41 am    Post subject: Reply with quote
Strange..the only place I've ever seen them is on the internet, but so many cars use them, I don't know why you don't see them in ordinary car parts shops.
Sounds like it wouldn't be easy to get the feeler gauge and spanner in there with the water pipe in the way.
I was looking at that, wondering what I'd use to unscrew it. ...Maybe a ruler?
Back to top
PostPosted: Wed Jan 04, 2006 2:40 am    Post subject: Reply with quote
To undo the plastic cirular plug, I modified a wood chiesel, making sure than all sharp edges were removed. Works well.
_________________
Back to top
Fil
PostPosted: Wed Jan 04, 2006 4:19 pm    Post subject: Reply with quote
It's a bit awkward, but not too bad with the right tools!
It wouldn't take much effort to drain the coolant and remove the water pipe from the head (just above the carb inlet stub on the right hand side) so you can move the water pipe out of the way.
I'll be investing in a set of angled feeler gauges too when I can find some!
Back to top
cat
PostPosted: Thu Jan 05, 2006 2:13 am    Post subject: Reply with quote
Always right tools. This time around I've got money - or at least compared to when I was 20 - so I go buy the tools. All I need now is a torque wrench that does 5-20Nm - and the valve clearance tools.
I think I've got pictures...there are some Wurth feeler gauges for valve clearance but they're quite hard to get, and about $27 for set of 2.) Then there are the Motion Pro ones - they're available all over the place - the web, I mean. They're not the old usual angled feeler gauges - which I haven't seen for years - since everything started coming from China, probably.
The Motion Pro ones ($4.35-4.75) (see picture below):
TAPPET FEELER GAUGE .002-.003
TAPPET FEELER GAUGE .004-.005
TAPPET FEELER GAUGE .006-.008
Also picture of Motion Pro tappet tool set; it looks good.
 Description:
 Filesize:  119.02 KB
 Viewed:  1372 Time(s)
 Description:
 Filesize:  5.36 KB
Back to top
cat
PostPosted: Thu Jan 05, 2006 2:23 am    Post subject: Reply with quote
Here you go:
http://www.abbeypowertools.co.uk/subprod/cylinder-and-valve-tools-0001413.aspx
...and kelkoo lists several:
http://shopping.kelkoo.co.uk/b/a/ss_feeler_gauge.html
Some of the ones there look better than others.
Now I just have to check if they do foreign orders.
Back to top
PostPosted: Thu Jan 05, 2006 12:50 pm    Post subject: Reply with quote
When I last checked my valve clearances I used a set of tappet adjusters like the ones in your picture. They are very easy to use. As for feeler gauges I bend some normal ones to fit.
_________________
Back to top
cat
PostPosted: Fri Jan 06, 2006 2:18 am    Post subject: Reply with quote
Yes, that's what we've always done with feeler gauges. The tappet adjuster tools, the only way I'm going to get any is to order them from the USA and they're heavy, so expensive. Maybe I can get just the square type.
Back to top
PostPosted: Fri Jan 06, 2006 11:52 am    Post subject: Reply with quote
I got mine from a company in teh UK called M&P a couple of years ago. Quite cheap if I recall. Dont know about P&P to where you live though
_________________
Back to top
Fil
PostPosted: Fri Jan 06, 2006 1:57 pm    Post subject: Reply with quote
Those are the ones I've got. Motion Pro, £25 plus P&P from M&P.
Back to top
cat
PostPosted: Mon Jan 09, 2006 2:34 am    Post subject: Reply with quote
Fil wrote:
Only about 10% less from USA, but shipping cost higher so about the same.
However, pitposse has copies. Which of these is the right one?
Posse Tappet Tool Set 9mm & 10mm
9mm & 10mm SOCKETS, 4mm SQUARE ADJUSTER, SINGLE CYLINDER AND MULTI-CYLINDERS.
MOST HONDA/YAMAHA.
Posse Tappet Tool Set 8mm & 10mm
8mm & 10mm ROCKER ADJUSTMENT NUTS SLOTTED AND 3mm SQUARE ADJUSTER, SCREW DRIVER & 3mm SQUARE-TIP APPLICATIONS.
KAWASAKI MODELS NINJA 600, 750, 900, 1000.
 Description:
 Filesize:  29.76 KB
 Viewed:  1265 Time(s)
Back to top
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
